robnicholson
Feb 04, 2019Aspirant
Daisy-chaining an access point to port on M4100
Kind of a newbie question as I've never really delved into managed switches. My client has an existing M4100 and a new one has been installed. I need to set-up a temporary access point off one of the...
DaneA
Feb 05, 2019NETGEAR Employee Retired
Hi robnicholson,
Just to verify. Is the new M4100 switch daisy-chained to the existing M4100 switch? Then, the two Cisco access points are directly connected to the new M4100 switch? It would be best if you post an image or screenshot of your detailed network setup showing the existing network and the ones you wanted to implement.
DaneA
NETGEAR Community Team
- schumakuFeb 05, 2019Guru - Experienced User
The limitation to one or two MAC addresses on the Cisco is for access ports, not for generic or trunk. Nothing to bother on the Netgear AFAIK.
