chelseagroup
Mar 02, 2019Follower
DCHP manual reservation limit
It appears that there is a 16 pool DCHP limit on this switch.
If assigning fixed (manual) ip addresses - it appears that the only way to do this is to assign 1 address to a single pool thereaby using 1 of the available 16(?) pools.
Is this correct (16 pools/reservation limit)?
Hi chelseagroup,
Welcome to the community ! :)
As per page3 of the M5300-52G (GSM7252S) data sheet here, it is indicated that up to 16 DHCP pools can be created. This is not a limitation. It is by design.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
Hi chelseagroup,
Regards,DaneA
