Barefootpanda
Feb 27, 2010Novice
Dead GSM7324 after Switch Recovery Tool?!
I purchased a switch second hand and was hoping to restore the software on it to get it back up and running. After getting the "unknown box topology" - seems common according to Google - I attempted ...
jmizoguchi
Feb 28, 2010Virtuoso
Barefootpanda wrote: Until who replies? Community? Netgear was no help. Just told me out of warranty and that I had no options. There isn't a paid repair program? There isn't a jumper I can reset to re-flash the boot rom? Seems like a major oversight in board design if you can't undo something...something that their software broke!!
no repairs. I have not heard jumpers to fix the issues.
usually TFTP is the way to load firmware etc.
you did but 2nd handed so blame is on you in the first place. forum is user to user only so someone might answer who had same issues with it.
