Barefootpanda
Feb 27, 2010Novice
Dead GSM7324 after Switch Recovery Tool?!
I purchased a switch second hand and was hoping to restore the software on it to get it back up and running. After getting the "unknown box topology" - seems common according to Google - I attempted ...
stevenb
Mar 11, 2010Aspirant
One thing to check is make sure your terminal program is setup properly - especially after firmware upgrades/restores etc. I've had oddities whereby the console wont refresh and the screen appears to be "stuck" at a certain point unless hitting return loads of times or mis configuration of terminal utility/crap serial cable etc. Putty is quite good :D
Also bear in mind, they may be lenient with the warranty (have you asked?) but I dont believe the warranty is transferrable to different users, sorry :(
