cigb
Dec 03, 2015Aspirant
Device view Java plugin not working
Currently I have installed two netgear managed switches: M5300-52G3 and GSM7248V2. I can't see the switch diagram in the Device view page. It reads "You need the Java Plugin. Get it from here" but "h...
- Dec 31, 2015
Hello anha,
You can try using a different computer that has not updated Java as a work around. We are still waiting for a fix and might take months.Or try the following:-Uninstall java 8-Manually install java 7Regards,
Pete127
Feb 09, 2016Aspirant
This is a problem with the highest line of products you sell, and yet you still have not fixed the problem. How long do you expect to keep peoples business? Other companies sell switches where all of the features work, but you don't. New products keep coming out with old problems. Why on EARTH is this not fixed yet?
Dansker
Feb 12, 2016Aspirant
Agree, this is dissapointing. Not even a date. I have this problem with several switches. Additonally, I can not get the GS516TP www interface to work at all with IE 11, except enter password. Have to use Edge, then still no device interface.
Sigh...
- DaneAFeb 14, 2016NETGEAR Employee Retired
Hi Dansker,
If ever the steps mentioned in this forum thread did not help, kindly open an online case with NETGEAR Support regarding your concern.
DaneA
NETGEAR Community Team
