FireAmpersand
Dec 02, 2020Aspirant
Devices on VLANs can not reach defualt gatway. But able to ping from other subnet.
Not sure if this is here is where i should be posting but I can't find any information about this anywhere. So i got a M4100-50G a year ago from a computer recycler. I just ran it as a switch without...
- Dec 02, 2020
After some digging around. It turns out I set the firewall rules wrong on the router. Everything is working now.
schumaku
Dec 02, 2020Guru - Experienced User
FireAmpersand wrote:I then tagged my ports where i have my servers in the VLAN Membership tab and set the Port PVID to match it.
Definitively wrong as described here. The port where the server is connected (by a flat network) must be an [U]ntagged member of VLAN 50 (and no other VLAN), and as you mentioned the PVID also to 50 (as this does define the VLAN where untagged frames from the server are assigned to.
FireAmpersand wrote:For example: Server1 is connected to port 13. I set port 13 to Untagged (U), PVID to 50 and LAG1 as Tagged (T).
This reads different and about right however..
Have no routing configured on the switch and enabled by error?
schumaku
Ohhhh OK - missed the reply. Have fun!
