KelvinFu's avatar
KelvinFu
DHCP accross multiple switches and vlans
Hi Community,
How can I get it work?
  • Hi KelvinFu
    Yes you want to create DHCP Server on your M4300 Managed switch and assign DHCP Pool for each VLAN with excluded IP address range each time..
    The way each DHCP pool is binded to its correct VLAN is simple: the network in each DHCP pool must belong to each VLAN IP interface subnet (or vice versa if you prefer).
    So if your VLAN 1 Routing IP Interface is 192.168.100.1 255.255.255.0, then your corresponding IP DHCP Pool <<DHCP_VLAN_1 or any other name>> should have its network such as 192.168.100.0 255.255.255.0
    You can refer to M4300 Admin manual and closely follow the example in Chapter 24 starting page 450 using either CLI or Web interface.
    You can select excluded IP range for each pool.
    All DHCP server parameters (including options) are available in M4300 technical documentation:
    Best regards,
    • KelvinFu's avatar
      KelvinFu
      oh, my question was not clear enough. as you know, i have servel vlan rite? so i guess i have to create dhcp pool and exclude range for each vlan? and I want to know, how can I match the pool to the correct vlan?
      • LaurentMa's avatar
        LaurentMa
        NETGEAR Expert
        Hi KelvinFu
        Best regards,
ProSupport for Business
