Liander's avatar
Liander
Guide
Oct 03, 2017
DHCP configuration on MX4300-48X
Hello Everyone,
I've got one configuration Issue: I'm new to the M4300 ProSAFE Switch and I'm trying to configure it. I've noticed that there is a DHCP server section under System -> Services and I need a little help to these question:
In my switch I've got several vlan mapped on a various number of ports. I'd like to enable DHCP on some vlan (let take an example):
Port 1 to 4 Vlan 20 subnet 192.168.0.0/24 (Need DHCP)
Port 5 to 8 Vlan 10 subnet 192.168.3.0/24 (No need for DHCP)
Port 9 to 12 Vlan 5 subnet 192.168.5.0/24 (Need DHCP)
No routing is needed between the Vlan.
How can I make this configuration?
Any help will be appreciated.
Thanks again
Luca
  • Liander,
    You are correct. Actually the last article that I just shared with you was the DHCP configuration on that, not the whole routing. You don't need to enable VLAN routing anymore on this setup as it will be handled already by your external router. So no need to worry about that. My apologies with the confusion.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Liander,
    Welcome to our community!
    Here is an article that will help you create DHCP server and DHCP pool on your network. Let us know if you do have any questions.
  • JohnC_V's avatar
    JohnC_V
    Liander,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
    • Liander's avatar
      Liander
      Guide
      Dear JohnCarloV,
      thanks for your first reply. I've followed all the insctuction on your link, but there is something that is not clear. It seem that it could be possibile to define more than one DHCP pool, so how is possible to assign the DHCP pool to a VLAN or to some ethernet ports? Is there any way?
      Thanks a lot for your help again
      Luca
      • JohnC_V's avatar
        JohnC_V
        Liander,
        To associate a DHCP pool to a VLAN, ensure that the network address of the pool matches the network address of the VLAN. For example, VLAN 10 in this example is assigned the IP address 192.168.10.254 and network mask 255.255.255.0. This has a network address of 192.168.10.0. When creating the DHCP pool for VLAN 10, ensure that the network address is 192.168.10.0 with network mask 255.255.255.0. The switch automatically assigns the DHCP pool to the corresponding VLAN (VLAN 10 in this case).
        Please refer on this article.
ProSupport for Business
