KFS-Bill
Feb 15, 2018Aspirant
DHCP pool options not saving
I have an M5300-52G-POE+ that is providing DHCP on several Vlans. I needed to change a DHCP pool option. I could not modify the IP address so I deleted the pool name to re-enter it. When I entered ...
DaneA
Feb 18, 2018NETGEAR Employee Retired
Hi KFS-Bill,
Welcome to the community! :)
I suggest the following steps below:
1. Clear the cache of the browser you are using then access again the web-GUI of the M5300-52G-POE+ switch and configure the DHCP pool again.
2. Use other browsers like Firefox or Chrome then login to the web-GUI of the M5300-52G-POE+ switch and configure the DHCP pool again.
3. Reboot the M5300-52G-POE+ switch then check if the same problem occurs.
4. If above steps did not help, I suggest you to update the firmware from v11.0.0.18 to v11.0.0.31. You can download firmware v11.0.0.31 here. Be reminded that its best to perform a factory reset after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Check if the same problem occurs.
DaneA
NETGEAR Community Team
KFS-Bill
Feb 23, 2018Aspirant
Hello Dane,
Since the M5300 in question, is my primary router, it's hard to take it offline to reboot.
Also when you say 'Factory Restore' you mean wiping all 52 ports and reprogramming from scratch?? REALLY??
How do I document all the settings?
We have 30+ Netgear switches M5300 M4300 M7100 S3300 WC7600 etc. I am a big fan of your products.
But I may need some hands-on help on this one. Can I speak with someone at Netgear Support?
- DaneAFeb 25, 2018NETGEAR Employee Retired
Yes, the settings will be reset to factory defaults then reconfigure the settings from scratch. In this way, we could have clean start using the latest firmware version.
If you want to have a copy of the present settings of the M5300-52G-POE+ switch, here are the steps:
1. In the web-GUI of the M5300-52G-POE+ switch, go to Maintenance > Upload > HTTP File Upload.
2. In the File Type field, select Text Configuration.
3. Click Apply
As reference, kindly read pages 488-489 of the ProSafe M5300 Switch Web Management User Guide here about HTTP File Upload from the M5300 Switch.
You may open a chat or online case with NETGEAR Support at anytime for technical assistance.
DaneA
