oxArt2Wave
Dec 07, 2017Aspirant
DHCP server ip pool limit on ProSafe M4100
Hi,
I'm trying out the DHCP server feature on the Prosafe M4100-26-POE. After reading the guide, I successfully created a IP pool. However I can't create more than 15 reserverations. Tried both web UI and CLI. Is this the hard limit for the switch? Seems kind of low.
(M4100-26G-POE) #configure
(M4100-26G-POE) (Config)#ip dhcp pool static_host_16
Couldn't create DHCP pool.
- HopchenProdigy
Hi oxArt2Wave,
It seems that you are trying to create more than 16 DHCP pools? There is a limitation on these switches, that they can only house max 16 pools, max 1024 leases. It is in the datasheet here:
http://www.downloads.netgear.com/files/GDC/datasheet/en/M4100.pdfIf you want to reserve IP address for specific clients, you can do that from within a DHCP pool. As described here, on page 385:
http://www.downloads.netgear.com/files/GDC/M4100/M4100_CLI_v10-0-2_20_Apr2015.pdf
Cheers- oxArt2WaveAspirant
Hi @Hopchen
Thank you for point out the limit in the data sheet. But that think Netgear is not be honest with customer. Peolple read the datasheet will think it means 16 DHCP Dynamic pools. It should not include other type such as (Unallocated and Manual).
I'm not trying to create 16 DHCP Dynamic pools. I created a single dynamic pool with a /24 subnet. Then started to create manual reservations within the subnet range by following the https://kb.netgear.com/21933/How-do-I-configure-a-Dynamic-Host-Configuration-Protocol-DHCP-reservation-using-CLI-commands-on-my-managed-switch. The web interface KB document suggests the same: https://kb.netgear.com/21934/How-do-I-configure-a-Dynamic-Host-Configuration-Protocol-DHCP-reservation-using-the-web-interface-on-my-managed-switch. There is no way of creating reservations within same DHCP pool configuration. Hence, each reservation will take one from the limit of 16.
- HopchenProdigy
Hi again,
Thanks for clarification. I understand what you are doing now. I've left for the day, but let me take a look at it, in our lab, when back Monday.
Cheers
