ChoiMJ's avatar
ChoiMJ
Follower
May 09, 2018
Down from 1 Gbps to 100 Mbps
I am using GS108E v3
"Linked Speed" changes in a few hours.
Can not set 1Gbps?
Firmware Version V2.06.03EN
* Client Setting
1 Reply
  • Retired_Member's avatar
    Retired_Member
    Hi ChoiMJ,
    Welcome to the community!
    Could you please set both switch port and PC port to auto-negotiate mode, and try again? I think the port will up at high-support speed(in your case, it should be 1Gbps).
    Hope it helps!
    EricZ
    NETGEAR employee
