TedW
Aug 09, 2017Aspirant
Dual DHCP helper-address in startup-config
I'm replacing my M5300 stack with a new M4300 stack and I had a question about a routing command in each of the VLANs on my old M5300 stack. My M5300 was configured by Netgear contracted support whe...
- Aug 09, 2017
Hi,
Here are the answers to your questions.
Question 1:
The ip-helper address is used for DHCP relay. You can also add this via the GUI, under "System" --> "Services" --> "DHCP Relay" --> "UDP Relay".Question 2:
The command vlan participation include will untag a vlan that on a given port (note, it will not set the PVID though). The command vlan participation exclude will remove vlan association on a given port.In the config file, you don't see the vlan include command for vlan 1, even though all ports are untagged for vlan 1 - as you mention. This is because that is the default setting. A config file only shows you what deviates from the default settings and since include vlan 1 is default on all ports, it won't show you that in the config file. Just like pvid 1 is set on all ports per default and you don't see that in the config file either.
Cheers
Hopchen
Aug 09, 2017Prodigy
Hi,
Question 1:
Question 2:
Cheers
