sahas1
May 12, 2025Aspirant
Dynamic RAM in GSM4352V1
I have a switch with serial 7FX13C5SA0330. I want to know the amount of dynamic ram (DRAM) that is available in the switch. I tried the checking the switch but it only shows CPU RAM which is just...
schumaku
May 13, 2025Guru - Experienced User
Hello sahas1 , welcome to the Netgear Community!
The physical memory is documented in the https://www.downloads.netgear.com/files/GDC/M4350/M4350_Datasheet.pdf
p.55
What is effectively available is the number shown on top of your listing.
Any specific issue you like to discuss?
-Kurt.
sahas1
May 13, 2025Aspirant
The system memory(RAM) of 2GB is the dynamic ram (DRAM) for this switch? If no, what is the value of the Dynamic RAM?
