chaneyr
Sep 04, 2015Follower
Enable UPNP
I recently purchased a Samsung Security Camera system for my business. In order for me to view video online or with my SmartPhone, I need to connect the Samsung DVR Camera system to the network. I use a Netgear GS608v3 Gigabit Switch that I plug directly in to. The DVR system can find the internet, but it wants UPNP to be Enabled in order to work. How do I enable UPNP on a Netgear GS608v3 Switch? I do not know how to log in to the Netgear Switch. It doesn't appear to be similar to a Netgear Router. Can someone help?
1 Reply
- SophostryAspirant
UPNP would need to be enabled on the router/firewall/gateway, not on the switch. Switches just send and receive traffic. The upstream device that connects to your modem, unless the modem is also the router, is where you need to look.
