luizluca
May 11, 2018Aspirant
Error while adding a new ACL rule
Hello,
While trying to attach an IPv6 ACL with 54 identical rules to a VLAN, I got this error:
(switchcore) (Config)#ipv6 traffic-filter acl-with-54-rules vlan 700 out 101 Unable to attach the specified access-control list to the specified VLAN.
If I add it with 53 rules and add the rule after it is aready attached, I get:
(Config-ipv6-acl)#permit icmpv6 any host 2606:4700:4700::1111 icmp-message echo-request
Error! processing ACL.
And logs only show for both cases this (useless) message:
DRIVER[emWeb]: broad_acl.c(2586) 474 %% ACL not applied to port CPU Interface: 0/5/1
I checked specs and I should have:
ACL Limits:
Maximum Number of ACLs (any type) 100
Maximum Number Configurable Rules per List 1023 ingress/511 egress
Maximum ACL Rules per Interface and Direction (IPv4/L2) 1023 ingress/511 egress
Maximum ACL Rules per Interface and Direction (IPv6) 1021 ingress/509 egress
Maximum ACL Rules (system-wide) 16384
Maximum ACL Logging Rules (system-wide) 128
Source: http://www.downloads.netgear.com/files/GDC/datasheet/en/M5300.pdf?cid=a page 35
If I'm reading it right, I could use up to 509 rules, not 53. I does not reach 509 even if I sum all rules from all existing ACL!
People normally do use specs in order to by a device. Are specs wrong here?
I'm using the latest firmware version: 11.0.0.31
- luizlucaAspirant
Hi DaneA
It seems that the switch cannot deal with more than 253 IPv6 vlan out rules globally, at least with firmware 11.0.0.31.
(switchcore) (Config)#no ipv6 access-list test123-out (switchcore) (Config)# ipv6 access-list test123-out (switchcore) (Config-ipv6-acl)#exit (switchcore) (Config)#ipv6 traffic-filter test123-out vlan 700 out (switchcore) (Config)#ipv6 access-list test123-out (switchcore) (Config-ipv6-acl)#permit ipv6 host 2001:efef:efef:efef:efef:efef:efef:1 any (switchcore) (Config-ipv6-acl)#permit ipv6 host 2001:efef:efef:efef:efef:efef:efef:2 any ... (switchcore) (Config-ipv6-acl)#permit ipv6 host 2001:efef:efef:efef:efef:efef:efef:253 any (switchcore) (Config-ipv6-acl)#permit ipv6 host 2001:efef:efef:efef:efef:efef:efef:254 any Error! processing ACL.
After that point I cannot use any new IPv6 or IPv4 vlan out rule (no problem with in rules).
It is way bellow what specs advertises.
I openend a suppor case #30125899 about it.
