kouya
Feb 21, 2017Aspirant
Ethernet Ports 1 and 11 (Dead), Not recognizing #show command in terminal mode
In terminal mode I can log into the switch but the show command comes back as error , tried to save config to NVram, the unit respond as can't save. I tried reset, reload, clear via terminal (usb) a...
DanielZhang
Feb 21, 2017NETGEAR Expert
Hi Rmolinari69,
Welcome to NETGEAR community! ![]()
Could you please follow belows checkpoint to diagnosis:
- What is the switch's name?
- Which version running on this switch?
- Port 1 and port 11 connected to which device?
- Please send the echo message to us after you input commands as below.(
such as:
show port status all
show port all
save(need to confirm the prompt)
show logging buffered
You can also send me a private message about echo message from CLI If any privacy you want to keep. ![]()
- kouyaFeb 22, 2017Aspirant
Switcher is currently bench checking without any network connections. I can connect w/PC on all ports except #1 and #11. Switch is M4100-D12-POE+ (GSM5212P) with the current FW 10.0.2.20 attached are screen shots. None of the "show" commands work.
- DanielZhangFeb 22, 2017NETGEAR Expert
Hi Kouya,
It seems that AutoInstall work in processon GSM5212P.
So the config file could not save to local.
Do you want to deploy the "AutoInstall" function on GSM5210P?
please input belows commands to disable this function and reload GSM5212P If you don't want to AutoInstall the GSM5210P
- Login GSM5212P.
- input Enable
- boot autoinstall stop
- no boot host dhcp
- no boot host autosave
- save(confirm with Y)
- reload
Did any configuration on port #1 and #11?
You can input below command to check.(before you input any command , please enter enable mode by “enable”)
1. show run interface #1(#1 is the port name of switch)
2. show run interface #11(#11 is the port name of switch)
3. show port all
4. show port status all.
- kouyaFeb 25, 2017Aspirant
Okay I tried the commands and the "Show run" commands will auto complete to "show running-config" > Also can't save the config file due to not enough room in the save location. Ports 1 and 11 still not active. I there a way to clear out the save locations?
