RobLigt
Apr 23, 2021Tutor
Extra ventilator-cooling for the M7100-24X?
Hello World!
I seek your guidance, experiences and tips please on the following:
I've been comissioned to move our Netgear M7100-24X's into smaller (= about 12HE) patch-cabinets.
Per 19inch rack, there will be 2x Netgear M7100-24X with each 2x powersupplies fitted (of course) next to the (default, I believe) 2x fan trays, per unit. (so in total 4x powersupplies & 4x fan trays in 1x 19 inch rack.
Naturally, I'm also looking into the cooling/heat-ventilation:
According to the data-sheet, the M7100-24X has a front-to-back airflow.
Where I believe the air-intake is on the side and exhausted via the twin fan trays at the back.
The patch cabinet has the option to mount 2x ventilators on top (roof), 2x on the bottom and 2x on each of the side-panels.
So, effectively, each side of the patch cabinet can have 2x ventilators mounted, if so needed.
Looking at the sizing of the 2x fan trays I believe they can keep the M7100-24X very nicely cooled effectively.
However, I can imagine 2x of those beasts into 1x smaller-size cabinet might need some ventilators to help dissapate the heat a bit better from the 19inch patch cabinet to the outside and aid the 2x M7100-24X to be a bit more effectively cooled.
May I ask, in the above described scenario, how many and where would you place additional ventilators?
I could be very wrong but perhaps 1x ventilator per side in push-configuration to create a positive airflow and 1x or 2x ventilators in the top in pull-configuration to guide the hot airflow towards the back-ish to the outside?
Any guidance, tips or links will be highly appreciated!
- DaneANETGEAR Employee Retired
Are these 19-inch rack where the M7100-24X will be placed, is it inside an air-conditioned room?
Kindly post photos of the 19-inch rack you are referring so that other community members who are familiar with it can post their suggestions and recommendations.
DaneA
NETGEAR Community Team
- RobLigtTutor
Thank you for your response, much obliged!
No, the M7100-24X's (2x per 19 inch rack plus the Netgear 1GBe switch) will be placed on the office workspace, per floor.
(so a total of 48x 10GBe ports and 52x 1GBe ports but I do not expect all ports will be populated due to the new way of working in pandemic times)As we are upgrading all workstations and servers plus whatever else has an ethernetport, to 10GBe where applicable.
So cooling (and heating) will be per regular typical office-space, no specific airconditioning is planned at this time.The 19 inch racks are the Rittal Rittal FB 7507.110 which is 9U's.
Here are some pictures;
- RobLigtTutor
