bengkyo's avatar
bengkyo
Help connected Netgear Prosafe M7100-24X - ProSafe 24-port 10G Port-Channel With Cisco Nexus 7000
Hii,
Im not used to using netgear, because i only have experience with cisco.
I have netgear M7100-24X 24 port, and connected with cisco 2 Nexus 7000.
I configure the netgear to nexus using port-channel with 2 link, 1 to N7000_A and one to N7000_B.
The problem is, at the netgear its only show only 1 port Up, eventhough i choose LAG, with port 0/23 and 0/24, but only port 0/23 came up.
at the netgear, i choose LAG with untagged only 1 vlan (vlan 44),
at cisco, i choose Access Mode with allowed vlan 44, and using port-channel 1
Can you guys helm me to solved my problem, i just wanna this 2 link netgear to the cisco is UP
herewith netgear config from GUI :
  • bengkyo's avatar
    bengkyo
    Sep 21, 2016
    Hii Atian,
    No, 1 Lag is fine, i already solved this problem :)
    My netgear M7100 have 2port 10G connection through nexus700_1 and 2 10G connection to nexus7000_2 and its all at LAG_1. The problem is, i should activated the vpc at port-channel at nexus7000_1 and Nexus7000_2.... (doooohh this is my bad how do i miss something like this >.< )
    So this case is closed, I now have 40G logical connection using LAG_1 at netgear to cisco Nexus7000_1 and Nexus7000_2
    Im using 1 Lag at Netgear M7100 who is connected to both cisco nexus7000.
    At nexus7000, just create port-channel and vpc for that connection (this is i forgot, adding vpc to port-channel netgear at nexus >.< )
    Its SOLVED :)
    Thanx DaneA for all your support, without your help i cannot find what is i miss ^.^
    -Kiky-
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi bengkyo,
    Welcome to the community! :)
    I believe setting up LAG the way you want to configure is not the correct way.  Kindly access and read the article below then use it as reference guide i setting up LAG on the M7100-24X switch.
    How to Configure LAG between two NETGEAR managed switches
    I believe this link I found online would be helpful as well.
    DaneA
    NETGEAR Community Team
    • bengkyo's avatar
      bengkyo
      Hii DaneA,
      Thanx for the reply, i already read the pdf file you mention it, and already follow the instruction before i post in here, it still have only 1 interface UP to my cisco.
      I followed the instruction on link above too, netgear with cisco, and still only 1 active, the other link standby.
      Is there any suggestion ?
      • DaneA's avatar
        DaneA
        Hi bengkyo,
        From your initial post, what I have understand is that you want to set up LAG between the M7100-24X switch and two Cisco Nexus 7000 switches wherein you have selected ports 23 and 24 of the M7100-24X switch. Port 23 of the M7100-24X switch is connected to one Cisco Nexus 7000 switch (N7000_A) and port 24 of the M7100-24X switch is connected to the other Cisco Nexus 7000 switch (N7000_B).  This is how you want to set up, am I correct?
        If ever I am correct, then the way you want to set up LAG between the M7100-24X switch and two Cisco Nexus 7000 switches is wrong.  It should be this way: for example, ports 23 and 24 of the M7100-24X switch should be connected to ports 23 and 24 of one Cisco Nexus 7000 switch (N7000_A) then ports 21 and 22 of the M7100-24X switch should be connected to ports 21 and 22 of the other Cisco Nexus 7000 switch (N7000_B).
        DaneA
ProSupport for Business
