bengkyo
Sep 15, 2016Aspirant
Help connected Netgear Prosafe M7100-24X - ProSafe 24-port 10G Port-Channel With Cisco Nexus 7000
Hii, Im not used to using netgear, because i only have experience with cisco. I have netgear M7100-24X 24 port, and connected with cisco 2 Nexus 7000. I configure the netgear to nexus using ...
- Sep 21, 2016
Hii Atian,
No, 1 Lag is fine, i already solved this problem :)
My netgear M7100 have 2port 10G connection through nexus700_1 and 2 10G connection to nexus7000_2 and its all at LAG_1. The problem is, i should activated the vpc at port-channel at nexus7000_1 and Nexus7000_2.... (doooohh this is my bad how do i miss something like this >.< )
So this case is closed, I now have 40G logical connection using LAG_1 at netgear to cisco Nexus7000_1 and Nexus7000_2
Im using 1 Lag at Netgear M7100 who is connected to both cisco nexus7000.
At nexus7000, just create port-channel and vpc for that connection (this is i forgot, adding vpc to port-channel netgear at nexus >.< )
Its SOLVED :)
Thanx DaneA for all your support, without your help i cannot find what is i miss ^.^
-Kiky-
Retired_Member
Sep 21, 2016in normal LAG, its peer ports must on the same device. so you need to creat two LAGs on M7100 like below.
port-channel linktrap lag 1
interface 0/23
no auto-negotiate
speed 10G full-duplex
addport lag 2
exit
interface 0/24
addport lag 2
exit
interface 0/21
no auto-negotiate
addport lag 2
exit
interface 0/22
no auto-negotiate
addport lag 2
bengkyo
Sep 21, 2016Aspirant
Hii Atian,
Its SOLVED :)
-Kiky-
