Boulc
Nov 23, 2019Follower
Factory default FSM7226
Hello,
I am trying to reconnect a FSM7226RS to my network but I lost the IP and the VLAN configuration. I am not able to access the admin web interface. Some port are configured with no VLAN (1-8) which allow some machines to see each others but not the switch.
I tried the EIA-232 port but I am never getting anything from the COM port of the connected machine.
Is there an easy way to factory default without software access ?
The reset button has no advanced behavior (press 10s / 30s) that would allow a hardware factory reset ?
Thanks in advance.
1 Reply
- kevin_hongApprentice
Hi Boulc,
Welcome commnuity,
Hold the "Reset" button for more than 10 seconds,
The switch will be factory default .
Thank you
