danclark
Jun 14, 2018Follower
Faulty switch
NetGear ProSafe GS728TP switch continually drop connection. I have factory reset it, updated firmware, downgraded firmware switched between the current-active dual image files and nothing has helped...
schumaku
Jun 17, 2018Guru - Experienced User
danclark wrote:
Does anyody know how to get in touch with support for warranty replacement without having to wait indefinatly on hold to speak with somone?
Use the my.netgear.com online portal - with the switch properly registered you can use Contact Support -> Replace my defective product
If properly assiged to your Netgear account, the case should be visible there anyway.
