star0815
Jun 11, 2019Tutor
Firmware update path M4300
Hi,
have some older firmware V12.0.4.9 on a M4300-8X8F, latest firmware is V12.0.7.15 ( https://kb.netgear.com/000060945/M4300-Firmware-Version-12-0-7-15 ).
Is is possible to update firmware directly to lastest available?
I have seen in other switch firmware release notes specific update paths, it is not mentioned here.
Thanks and best regards,
Raphael
You may proceed with the firmware update directly to v12.0.7.15. Just to be safe, have a backup of your current settings.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
Regards,DaneA
