rdraper
May 17, 2016Follower
FS726T Unable to upgrade Firmware
I have an FS726T that i'm struggling to upgrade firmware on, its still on V1.2.3_02 so needs updating in Smartwizard Discovery Utiltiy and not Smart Control Center software, i can not find a copy of ...
Retired_Member
May 17, 2016FS726T is a Smart Switch with a Web Interface. You should be able to connect to the web GUI and upgrade the F/W from there. The use of the utility is not mandatory for Smart switches.
If you really want the old utility, go to http://downloadcenter.netgear.com/ and search for FS726TP. This one has the link.
