rdraper
May 17, 2016Follower
FS726T Unable to upgrade Firmware
I have an FS726T that i'm struggling to upgrade firmware on, its still on V1.2.3_02 so needs updating in Smartwizard Discovery Utiltiy and not Smart Control Center software, i can not find a copy of ...
Retired_Member
May 17, 2016FS726T is a Smart Switch with a Web Interface. You should be able to connect to the web GUI and upgrade the F/W from there. The use of the utility is not mandatory for Smart switches.
If you really want the old utility, go to http://downloadcenter.netgear.com/ and search for FS726TP. This one has the link.
JohnRo
May 23, 2016NETGEAR Employee Retired
Hi rdraper,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
