zwartemerel's avatar
zwartemerel
FS726TP - vlan cannot acces other device
Situation
FS726TP switch
setup 2x vlan
Vlan1 - untagged - ports 1-8 / 13-24
Vlan2 - untagged - ports 9-12
Vlan1 - windows server dhcp - 192.168.10.x range
Vlan2 - draytek2920 port4  dhcp router 10.10.1.x range
port 1 from draytek to port 1 of netgear
port 4 from draytek to port 9 of the netgear
Vlan 1 works fine like normal network
Vlan 2 work only for internet , ill get on port 10-12 a ip adres from the 10.10.1.x range, and internet goes fine
ive connected a pc on port 10, and also a good 10.10.1.x ip adres when i try to ping to a switch/nas/ipcamera on 1 of the otherports i have no problems
but when i try to reach the other devices on the webinterface i cant get contact, in some cases the name of the page are shown in the titlebar, but then he keeps loading, without result
i have also tried to create a port based vlan, with the same results.
in the other range, i havent any trouble
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi zwartemerel,
    Welcome to the community! :)
    Here are my questions below:
    a. If you connect the device/s (NAS, IP camera, etc.) directly to a PC, are you able to access the web interface of the device/s?
    b. What is the current firmware version of the FS726TP?
    c. What is the Operating System of the computer you are using to access the web interface of the device/s?  Is it Windows 10/8//7/Vista/XP or MAC?
    d. Have you check the IP setting (such as DNS, default gateway) of the device/s you want to access the web interface?
    I look forward to your response.
    DaneA
    NETGEAR Community Team
    • zwartemerel's avatar
      zwartemerel
      Hello,
      after some experience, i find out the connection to the other devices gives the problems,
      a other switch in the network gives the troubles.
      its all fine now ;-)
      Henri
      • DaneA's avatar
        DaneA
        Hi zwartemerel,
        I am glad to know that everything is fine now. :)
        Feel free to post your future concerns here in the community.
        Cheers,
        DaneA
ProSupport for Business
