Milesdeep
May 25, 2016Tutor
FS728TP Switch-How to set IP for VLAN
I have the above mentioned switch and I can find where to create the various VLANs, I just cannot figure out how to route between the VLANs. How do I assign the VLAN an IP?
- May 26, 2016
Hello Milesdeep,
Welcome to the community!
The FS728TP is only a layer 2 Smart Switch, such features like Inter-VLAN routing are not available on these models. You will find Inter-VLAN feature on a router with VLAN capability (VLAN aware) or a Layer 3 switch. For more information about Smart Switches please click here.
Thanks,
Milesdeep
May 25, 2016Tutor
I read that there is a "Routing" tab. I don't have one. I try to update the firmware but it says my unit is up-to-date. Inter-VLAN routing? Maybe not on this model? So, what's the point of VLANs if you can't route between them?
JohnRo
May 30, 2016NETGEAR Employee Retired
Hi Milesdeep,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
- MilesdeepJun 02, 2016Tutor
Thanks for the comments, I didn't not know it was a layer-2. I'll work accordingly. Thanks.
- JohnRoJun 02, 2016NETGEAR Employee Retired
Hello Milesdeep,
You are welcome! Feel free to ask if you have more questions otherwise please consider marking "Accept as Solution" on one of the posts that helped you. This will help other users maximize thier search when looking up answers in the community.
Thanks,
