thermoman
Jan 08, 2008Aspirant
FSM726 crashing
Hi, we're using two FSM726 connected via a central GSM7224 switch. Both FSM726 switches are crashing from time to time (not at the same time). When this happens no packets are being forwarded...
thermoman
Jan 05, 2012Aspirant
I opened a case with Netgear and now RMA'ed the broken device.
Replacement device will be FSM726v3 (alias FSM726-300), the successor of the FSM726v2.
I hope the new device does not have this issue :)
@jmizoguchi
The FSM726v2 was bought back in february of 2007 which makes the limited warranty expire in feburary this year. Luckily we checked whether the switch has still warranty. if it wouldn't have we would have bought a new switch from another vendor.
Let's see if this works out.
thermoman.
@jmizoguchi
thermoman.
