marioalpha's avatar
marioalpha
FSM726 V2H2 first configuration
I set up this model, I did access via com port, I am required username and password, I tried with user admin and passwword:
blank
password
1234
but I can not access.
I also did a hard reset but can not log in.
Booting...
Memory Test ...
Decompressing...OK
System database initialization ... OK
SPI unit 0: Dev 0xBC20, Rev 0x02, Chip BCM5324_A2, Driver BCM5324_A1
PCI unit 1: Dev 0x4713, Rev 0x06, Chip BCM4713_A0, Driver BCM4713_A0
Attaching SOC unit 0...
Attaching SOC unit 1...
BCM Test - PASS
PHY Test - PASS
INTPHYLB Test - PASS
Switch boot from local image ...
Checking Image Bank Integrity ...  OK
Booting system ...
Decompressing ...OK
SPI unit 0: Dev 0xbc20, Rev 0x02, Chip BCM5324_A2, Driver BCM5324_A1
Attaching SOC unit 0... SPI device BCM5324_A2 attached as unit 0.
Attaching SOC unit 1... Broadcom BCM47xx 10/100 Mbps Ethernet Controller 2002.9.27.0
........... OK
  • DaneA's avatar
    DaneA
    Dec 03, 2015
    Hi marioalpha,
    This is the link where I got the steps that I have summarized for you recently.  However, let me share this old forum thread I found and it might help.  Take note that some of the links on the old forum thread I have shared are not active anymore.  Possible reason here might be that the FSM726 is an old model of a managed switch.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi marioalpha,
    Welcome to the community! :smileyhappy:
    It seems that you might need to reset the CLI password.  Here are the steps below to reset the password:
    a. While booting up, press to enter boot code menu.
    b. Press in boot code main menu to enter debug menu.
    c. Press "5" to choose "Flash Access."
    d. Press "2" to choose "Flash Erase."
    e. "Start of sector #": Press 23 Enter.
    f. "End of sector #": Press 31 Enter.
    g. Confirm this command.
    Hope it helps.
    DaneA
    • marioalpha's avatar
      marioalpha
      when I Press "5" to choose "Flash Access"  do not go into any menu :-(
      • DaneA's avatar
        DaneA
        Hi marioalpha,
        DaneA
ProSupport for Business
