sharpescalade
Aug 07, 2007Follower
FSM726 Password/Login Problem PROS PLEASE HELP??
thank you for your time... I bought a Netgear FSM726 V1 Managed Switch from a company going out of business. I do not have any information about its configuration including console and web configu...
g707
Sep 18, 2007Aspirant
I'm having the same problem, neither procedure works.
Has anyone been able to get the password recovery to work on the FSM726 v1 (mine's got the original firmware).
TFTP boot w/ newer firmware doesn't reset the password either.
