sharpescalade
Aug 07, 2007Follower
FSM726 Password/Login Problem PROS PLEASE HELP??
thank you for your time... I bought a Netgear FSM726 V1 Managed Switch from a company going out of business. I do not have any information about its configuration including console and web configu...
chrisjenx2001
Aug 19, 2008Novice
g707 wrote: Per Netgear support, pass along to help anyone else out:
Here are the steps that you should try to reset the password :
FSM726v2 (reset procedure)
1. While booting up, press to enter boot code menu.
2. Press in boot code main menu to enter debug menu.
press what to enter the boot menu?
