vanmalt's avatar
vanmalt
FVS318G v1 cut out internet
My FVS318G v1 will cut out the internet multiple time in single day.
I'm not using VPN and I'm not any sort of filtering.  I'm using NAT and have a basic configeration
Please help.
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello vanmalt,
    Welcome to the community!
    I have some questions for us to isolate the issue properly, I have listed them below:
    1. When you lose internet connection, do you still have access to the web UI of the router?
    2. Are you still getting a public IP on the router when the issue happens?
    3. Does the WAN light on the router turn off?
    4. When a computer is directly connected to the modem, do you experience the same issue?
    5. What changes have you made to your network before the issue started?
    6. What is the firmware version currently installed on the router?
    Looking forward to your response.
    Thanks,
    • vanmalt's avatar
      vanmalt
      1.  I have access to the web UI just not the internet.
      2.  I'm not sure what you are asking.  does the router display the broadband IP address?
      3.  No
      4.  Same issue.  no internet
      5.  none
      6.  3.1.1-08
      • DaneA's avatar
        DaneA
        Hi vanmalt,
        Regarding your answer on question no. 4, you have mentioned "same issue. no internet" which means that you have no internet access if you connect a PC directly to your modem.  You need to contact your Internet Service Provider for assistance to resume internet connection.
        Also, about question no. 2 regarding about the Public IP Address that was asked, kindly access the web-GUI of the FVS318Gv1.   Then, go to Monitoring > Router Status then check the IP Address on the Broadband Configuration section.  Kindly refer to the image below:
        DaneA
        NETGEAR Community Team
ProSupport for Business
