htc20101
Feb 24, 2015Aspirant
GS105E, GS108E, and WG102, all in a VLAN - how?
I have a GS108E connecting 4 point of sale systems, linking to a GS105E connecting to a point of sale server and WG102 access point with 2 VLAN's on 2 SSID's.
However, I am very unclear on how to separate traffic from VLAN1 on SSID1 from all the VLAN2 traffic which hosts the point of sale systems and server. Here is what I did:
GS105E
Ports 1 through 5: PVID1, all flagged as "U" VLAN 1
Ports 4 (server): PVID2, flagged as "U" VLAN2
Ports 1 (AP): PVID1, flagged as U VLAN1 and U VLAN2
But this setup just doesn't quite work as I cannot get traffic between the AP to the switch. The logic is not quite clear. This setup is actually a bit more complicated. I'd love to PM someone for some very in-depth step-by-step on how to do this as we do need this working for PCI Compliance come October 31st of this year.
- fordemMentorThe "separation of traffic" is done based on "VLAN tags" - tags that the switch append to the data packets marking them - the connection between the switch and the AP must pass these VLAN tags through to the AP so the switch port has to be set as "T". Sorry I can't help with step-by-step as I have never used that equipment.
Sorry I can't help with step-by-step as I have never used that equipment. - htc20101AspirantThe logic on the GS105E and the 108E are a little strange in that to maintain Internet connectivity, all ports must remain an untagged member of VLAN1. The manual actually tells us to move ports to their appropriate VLAN as needed. But anyhow, I was able to work this through and the system works. So this is what I have accomplished:
1. Point of Sale terminals + their server on are VLAN3
2. Wifi AP is configured with 2 SSID's on VLAN1 and VLAN3, respectively
3. Wifi SSID on VLAN1 cannot ping or see anything on VLAN3 and vice-versa
4. Internet works on VLAN3 and VLAN1
However, two problems:
1. Wifi SSID on VLAN3 can see other devices, but cannot reach router/internet.
2. All the lights on all ports on the switches are blinking incessantly now. Is this normal? I'm used to the unamanged switches that blink only when a port is in active use.
To visualize:
Cisco RV082 router ----> GS108E ----> GS105E ----> (1) Server + (2) WiFi AP
The GS105E port to the WiFi AP is a VLAN member of 1 and 3, T
The GS105E port uplink to the GS108E is also T VLAN1 and 3
The uplink port from the GS108E to the Cisco RV082 is U VLAN1 and VLAN3
PVID's are 1 between all uplink ports, VLAN3 for all access ports.
