rexdb
Jul 31, 2011Follower
GS108T loses all throughput
I have two GS108T switches (GS108T-100AUS series V3.0.2 firmware). Every few weeks one or both of the switches gets itself into a state where the power LED is lit but no other LEDs are lit. All the li...
fordem
Jul 31, 2011Mentor
Power supply voltage may play a part.
I have a GS108T that would display those exact symptoms when power was restored after an outage (the switch is fed from an APC SmartUPS that is set to shut down 5 mins after a utility failure and restore power to the equipment 1 minute after utility comes up), and discovered that the voltage from the adapter was fractionally low - I swapped the adapter for another one (from a Netgear print server) and the problem went away.
