MarcoDG
Sep 26, 2017Aspirant
GS110TP - PoE not working
Hello Community, I'm having problems while trying to get PoE working. I'm trying to power two IP cameras compatible with 802.3af Configuration: - GS110TP reset to factory settings, then upd...
- Sep 27, 2017
Hi MarcoDG,
Welcome to our community!
As per checking in here that you do have two IP cameras that isn't working with the POE. Normally, switches doesn't need anything to power up a POE device, unless they are incompatible and doesn't have the same protocol. May I know what is the camera that you are using? What model? At first, you may just try to reset it first to factory default and just plug in the IP camera and see if that will work. Try all the ports just to isolate the issue.
JohnC_V
Sep 27, 2017NETGEAR Employee Retired
Hi MarcoDG,
