MarcoDG
Sep 26, 2017Aspirant
GS110TP - PoE not working
Hello Community, I'm having problems while trying to get PoE working. I'm trying to power two IP cameras compatible with 802.3af Configuration: - GS110TP reset to factory settings, then upd...
- Sep 27, 2017
Hi MarcoDG,
Welcome to our community!
As per checking in here that you do have two IP cameras that isn't working with the POE. Normally, switches doesn't need anything to power up a POE device, unless they are incompatible and doesn't have the same protocol. May I know what is the camera that you are using? What model? At first, you may just try to reset it first to factory default and just plug in the IP camera and see if that will work. Try all the ports just to isolate the issue.
MarcoDG
Oct 02, 2017Aspirant
Hi JohnCarloV,
I'm sorry about not providing a feedback, I wasn't at home to test it.
However it seems that only port 4 is able to provide poe, while port 3 emits an audible electrical noise. I'm going to return this unit to the reseller.
Thank you very much for your help!
Marco
Marco
JohnC_V
Oct 02, 2017NETGEAR Employee Retired
Just in case that your reseller won't replace it. You may open a chat / case online on NETGEAR support and please let them know the status of your switch so that we can replace it. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
