ITO
Apr 30, 2018Aspirant
GS110TP Firmware update not working through SmartControlCenter
Hello, SmartControlCenter 1.1.3.4 Netgear GS110TP I'm trying to use SmartControlCenter to update the firmware on my GS110TP switches, but it always fails with "File transfer read / write error...
JohnC_V
May 01, 2018NETGEAR Employee Retired
Hi ITO,
Welcome to our community!
It seems that you pretty isolated the issue with different switches. Please try to downgrade the Smart Control Center to v1.3.3.3 and also try to use other PC to upload the firmware.
- ITOMay 01, 2018Aspirant
Hi JohnCarlo,
Thanks for respondng. I have tried it on 2 computers and in fact I started with an older version of SmartControl and updated to the latest when I encountered the problems as described.
JohnC_V wrote:
Hi ITO,
- JohnC_VMay 08, 2018NETGEAR Employee Retired
ITO,
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- ITOMay 13, 2018Aspirant
Hi JohnCarlo,
I tried disabling firewall and anti virus, but no improvement.
Thanks for looking into this. Any other suggestions?
