dmac001
Jan 16, 2024Tutor
GS308EPP 8023.af support 24v passive Ubiquiti AP
Hi, can anyone tell me if the GS308EPP will support a 24 volt passive Ubiquiti AP with 8023.af? All the documentation talks about power consumption, watts,... but not volts. I'm assuming the GS308E...
schumaku
Jan 16, 2024Guru - Experienced User
The GS308EPP does only support active PoE, an active IEEE compliant powered device must be connected to the IEEE PSE before the switch does bring up a voltage to the wires.
Mute to talk about voltage - because it's not cheap passive PoE. The IEEE standards for 802.3af, 802.3at, and 802.3bt has certainly definitions for the exact voltages - the user does not have to care about however. That's why you rarely see voltages on the spec sheets.
To answer the question:
No!
