dmac001
Jan 16, 2024Tutor
GS308EPP 8023.af support 24v passive Ubiquiti AP
Hi, can anyone tell me if the GS308EPP will support a 24 volt passive Ubiquiti AP with 8023.af? All the documentation talks about power consumption, watts,... but not volts. I'm assuming the GS308E...
dmac001
Jan 16, 2024Tutor
Thanks for the replies. I'm still a little confused. My Ubiquiti AP supports both 24v passive POE and 802.3af POE. The GS308EPP supports 802.3af POE and 802.3at POE+ so "in theory" I should be able to power the AP from one of the GS308EPP ports.
Do I risk this or use the 24v passive injector?
Thanks again,
Don
schumaku
Jan 16, 2024Guru - Experienced User
They had do support both because Ubiquity has to much passive PoE devices in the market.
What theory please? How do you expect a IEEE 802.3at PoE PSE provide power for a non-standard compliant "passive" 24V device? Or have you read somewhere in a Netgear PoE switch data sheet e.g. this GS308EPP does allow powering "passive" 24V devices'
No risks involved from a industry standard 802.3af, 802.3at, or 802.3bt PSE - be assured you can connect any industry Ethernet device to any of these PSE ports without a risk. Very different with using non-standards compliant passive injectors or passive PoE switch ports or the like.
For reasons, the standards were carefully defined and implemented. This is why the industry has preferred IEEE 802.3 compliant PoE implementations, preferred over some dirt cheap and risky design. Yes, it's additional effort for the PSE as well as for the PD hardware design. Good to see Ubiquiti Networks, Motorola [new name: Cambium] and MikroTik among with some niche players is on the right way, also supporting industry standards in the PoE environment.
Some five or six years ago, Ubiquity Networks started moving all new UniFi devices to 802.3af/at/bt, depending on power requirements. Unclear is what will happen in the lifecycle of the EdgeMax using (mostly) 24V passive, the big big AirFiber radios appear still use 54V passive when I have it right. Time of "passive" PoE will come to an end as the standard can provide 60W at the PSE (with 51W at the PD) 802.3bt Type 3, resp. 99.9W at the PSE (with 71.3W at the PD after max cable loss) in 802.3bt Type 4.
- dmac001Jan 16, 2024Tutor
I agree, the Ubiquiti APs with non-standard 24v/48v passive POE unnecessarily confuses the space.
My "newer" AP-Lite (build 33) supports 802.3af (and as labeled on the bottom) so it should work with the GS308EPP; however, it also runs with 24v passive POE which I thought would be a problem with 48v 802.3af POE.
I should have the replacement switch tomorrow, so I'll be able to confirm. Thanks again for all the comments!
Don- dmac001Jan 18, 2024Tutor
Just to close out this discussion, my Ubiquiti AP 802.3af works fine with the Netgear GS308EPP. Thanks for everyone's comments.
