rt_677223
Feb 23, 2023Follower
GS308EPP with passive PoE device?
I'm looking for a PoE switch to power a couple of devices in my home. I want to by the GS308EPP (123w) Netgear Switch. Now I'm dragged into the PoE rabbit hole and not sure about what's possible and ...
schumaku
Feb 23, 2023Guru - Experienced User
The GS308EPP won't blow up your Passive "PoE" device, but can't power it either. If you decide adding a power injector matching this passive PoE device, double check it's after (upstream), between the switch and the AP.
