woodgee
Oct 31, 2019Aspirant
GS510TLP and AGM731F SFP Module - NO LINK to TP-Link T2600G-52TS
Hello, i have an new GS510TLP 8-Port POE Switch with 2x AGM731F SFP Modules. The Swich have the latest Firmware 7.0.0.20 installed. When i connnect the GS510TLP over the AGM731F SFP Modules wit...
woodgee
Nov 01, 2019Aspirant
Hello schumaku,
i have tested the connection with a different cable (same type), but there is no difference,
the tp-link switch shows me an link on the sfp module (led indicator and web interface).
the Netgear shows me no link on the sfp module (led indicator and web interface).
i have tested both sfp ports on the netgear (port 9 and port 10) with different sfp modules and
i have tested two different sfp ports on the tp-link, with different sfp modules -> NO LINK ON THE NETGEAR SWITCH
so i think there is no faulty sfp module and no faulty cable.
it must be something else, maybe the firmware on the Netgear switch?
bad initial handshake?
schumaku
Nov 01, 2019Guru - Experienced User
There is no autonegotiation on SFP/SFP+ ports and fiber links - that's why I think Netgear is right not to show this control.
Get in touch with the Netgear support via https://my.netgear.com/
- woodgeeNov 01, 2019AspirantToday I have checked the following things:
tp-link switch via sfp to tp-link switch sfp -> works link is up and data pass the link
tp-link switch via sfp to unifi switch sfp -> works, link is up and data pass the link
tp-link switch via sfp to netgear switch sfp -> no link
unifi switch via sfp to netgear switch sfp -> no link
netgear switch sfp port 9 to netgear switch sfp port 10 -> link is up (led indicates the link and webinterface shows the link up)
-> there must be an problem with the netgear switch, i think an firmware problem ??
