DucaNet
Sep 25, 2016Aspirant
GS516TP - Newbie Totally lost.
Hi, So I just upgraded to this switch from an unmanaged 8 Gb ports Cisco. I needed more ports and power since I already have 4 IP Cams and plan on adding more. Also I was interested in the LACP t...
DaneA
Sep 26, 2016NETGEAR Employee Retired
Hi DucaNet,
Welcome to the community! :)
Kindly answer the questions below:
a. On the web-GUI of the GS516TP switch, go to Switching > Ports > Global Configuration. Is Flow Control enabled?
b. What is the current firmware version of the GS516TP switch?
DaneA
NETGEAR Community Team
- DucaNetSep 26, 2016Aspirant
Hello,
a. Disable
b. I only see Boot Version: 2.0.0.11 and Software Version: 6.0.1.16 (< firmware?)
- DaneASep 27, 2016NETGEAR Employee Retired
Hi DucaNet,
You have just replaced your unmanaged Cisco switch with the GS516TP switch and the network became slow. Kindly try the following:
a. Enable Flow Control and observe if it will improve the network speed.
b. Factory reset the GS516TP if enabling flow control doesn't help.
Let us know the results.
DaneA
- JohnRoSep 30, 2016NETGEAR Employee Retired
Hi DucaNet,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- DucaNetOct 02, 2016Aspirant
Sorry I'm returning the switch. In my case it just doesn't improve things but make them worse e.g. LACP and Qos.
Even for my many devices it doesn't make sense to have that much manageability and bandwidth. Thanks for your help/time!
