DucaNet
Sep 25, 2016Aspirant
GS516TP - Newbie Totally lost.
Hi, So I just upgraded to this switch from an unmanaged 8 Gb ports Cisco. I needed more ports and power since I already have 4 IP Cams and plan on adding more. Also I was interested in the LACP t...
DucaNet
Sep 26, 2016Aspirant
Hello,
a. Disable
b. I only see Boot Version: 2.0.0.11 and Software Version: 6.0.1.16 (< firmware?)
DaneA
Sep 27, 2016NETGEAR Employee Retired
Hi DucaNet,
You have just replaced your unmanaged Cisco switch with the GS516TP switch and the network became slow. Kindly try the following:
a. Enable Flow Control and observe if it will improve the network speed.
b. Factory reset the GS516TP if enabling flow control doesn't help.
Let us know the results.
DaneA
NETGEAR Community Team
