ryanvox
Aug 04, 2016Aspirant
GS608v4 switch no gigabit speeds but works fine GS605v4 switch
Sorry for the wrong model listed above. When listing what hardware you are having trouble with they don't have anything for switches under Home Use. I apologize for the confusion. I have been usin...
JohnRo
Aug 05, 2016NETGEAR Employee Retired
Hello ryanvox,
Welcome to the community!
Well, this is pretty much isolated and points out to the GS608. This is a bit hard to troubleshoot since the switches are all passthrough units. If you have tested it on different locations and still shows slow speed then there could be something wrong with the switch. Try a test with only 2 computers connected to the GS608, assign static IPs on them and do a file transfer. If you will still get slow speeds, might as well contact our Support Team and have it replaced.
Thanks,
ryanvox
Aug 05, 2016Aspirant
Thank you for your response. I think I found the problem. I had all 8 ports plugged in. I unplugged 6,7, and 8 and did a file transfer again and I got the speeds I was looking for. I don't know why having ports 6,7, and 8 plugged in would slow down 1, 2, 3, 4, and 5. I think I am gonna get a different switch though. Thanks again.
- JohnRoAug 08, 2016NETGEAR Employee Retired
Hi ryanvox,
You're welcome! It does not seem to make sense to me that it does not give the correct speed when all of the ports are occupied. Something is clearly going on with the device(s) but it will be hard to locate since this switches are only pass throughs.
Let us know if you have more questions, otherwise please mark the post as "Accept as solution".
Thanks,
- JohnRoAug 11, 2016NETGEAR Employee Retired
Hi ryanvox,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
