ryanvox
Aug 04, 2016Aspirant
GS608v4 switch no gigabit speeds but works fine GS605v4 switch
Sorry for the wrong model listed above. When listing what hardware you are having trouble with they don't have anything for switches under Home Use. I apologize for the confusion. I have been usin...
ryanvox
Aug 05, 2016Aspirant
Thank you for your response. I think I found the problem. I had all 8 ports plugged in. I unplugged 6,7, and 8 and did a file transfer again and I got the speeds I was looking for. I don't know why having ports 6,7, and 8 plugged in would slow down 1, 2, 3, 4, and 5. I think I am gonna get a different switch though. Thanks again.
JohnRo
Aug 08, 2016NETGEAR Employee Retired
Hi ryanvox,
You're welcome! It does not seem to make sense to me that it does not give the correct speed when all of the ports are occupied. Something is clearly going on with the device(s) but it will be hard to locate since this switches are only pass throughs.
Let us know if you have more questions, otherwise please mark the post as "Accept as solution".
Thanks,
