tClancey
Nov 10, 2018Tutor
GS724 - GS748 firmware??
Hi there.
I'm currently setting up a bunch of LAGs on a GS724, this branches off to 3x GS748s, and I want to give as much bandwidth to each as I can.
I've inherrited these units and this ...
tClancey
Nov 11, 2018Tutor
Sorry, I should have said, all ar v3.
The trunk setup is so easy with the 24 port, with the 48 it all seems backwards and I'm unable to get any lag lines setup, everything I try loops and bombs the network.
But it should be possible to do?
I must admit, I'd be amased if it wasn't.
DaneA
Nov 12, 2018NETGEAR Employee Retired
Hi tClancey,
The latest firmware version for the GS748Tv3 is v3.1.4 while the latest firmware version for the GS724Tv3 is v5.4.2.30.
For the GS724Tv3, I suggest you to upgrade the firmware in a ladderized manner. First, upgrade the firmware from v4.2.1 to v4.2.1.5. Then, from v4.2.1.5 to v4.2.1.8 and so on until you reach the latest firmware version which is v5.4.2.30. Be sure to perform a factory reset on the the GS724Tv3 switch/es after upgrading to the latest version then reconfigure the settings from scratch in order to start clean using the latest firmware version.
You may want to take screenshots of the settings configured on the GS724Tv3 switch/es before you proceed with upgrading the firmware. It is because the config file you saved from firmware v4.2.1.x will not be restored once the firmware has been upgraded to v5.x.x.x. You can download the firmware versions for the GS724Tv3 switch here.
DaneA
NETGEAR Community Team
