jfriesne
Feb 15, 2012Novice
GS724T: How to filter outgoing IPv6 multicast packet to a port?
Hi all, I've got a GS724T switch, with the latest firmware (5.0.3.5) installed. The devices on this switch generate a lot of IPv6 multicast traffic (for distributed database synchronization and ...
jfriesne
Mar 07, 2012Novice
FWIW, a co-worker was finally able to figure out how to do this, by using the "Storm Control" feature to disable incoming multicast packets on a port, and putting both that port and a second port onto their own separate VLAN. Then the filtered port gets connected to another port on the switch via, and the second port gets connected to the WiFi access point, and presto, no multicast packets go out onto the WiFi.
