evb
Oct 08, 2013Guide
GS724T not be able to set time
Hi, I'm trying to set the time via the webinterface, Time, SNTP Global configuration. First I tried to use the SNTP option, but because this didn't work, I tried the local option. I encode the c...
jmizoguchi
Oct 13, 2013Virtuoso
GS724T has many model version. (support.netgear.com)
If the products is NOT EOL then contact support via portal at my.netgear.com
EOL products will not get any fixes so if that the case you are out of luck :)
You an also Check EOL list here at netgear.com/eol
