dbecker
Aug 03, 2017Aspirant
GS728TP - Looking for a way to disable 'Validate IGMP IP Header'
ll, I am looking for an option to disable 'Validate IGMP IP Header' in a Netgear GS728TP Managed switch. I found a help article which seems to indicate that I should see this option in the web U...
JohnC_V
Aug 04, 2017NETGEAR Employee Retired
Hi dbecker,
Welcome to the community!
You should be seeing the options that is showing on the article as you are using a GS728TP switch. I don't think that we can set it up on CLI as it doesn't have any serial port.
Please check the manual here(page 108).
