dbecker
Aug 03, 2017Aspirant
GS728TP - Looking for a way to disable 'Validate IGMP IP Header'
ll, I am looking for an option to disable 'Validate IGMP IP Header' in a Netgear GS728TP Managed switch. I found a help article which seems to indicate that I should see this option in the web U...
JohnC_V
Aug 08, 2017NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- dbeckerAug 08, 2017Aspirant
The option was not in the web interface, but I am not sure I was looking at the correct manual when I saw the entry in the first place. All told I dont believe you can disable this feature in this switch as far as I can tell.
