dbecker
Aug 03, 2017Aspirant
GS728TP - Looking for a way to disable 'Validate IGMP IP Header'
ll, I am looking for an option to disable 'Validate IGMP IP Header' in a Netgear GS728TP Managed switch. I found a help article which seems to indicate that I should see this option in the web U...
dbecker
Aug 08, 2017Aspirant
The option was not in the web interface, but I am not sure I was looking at the correct manual when I saw the entry in the first place. All told I dont believe you can disable this feature in this switch as far as I can tell.
